Fellows,i boight this mm 445 2 years ago..ehgine is strong,pto strong,fel strong,high range gear lever works well.overall im very happy with this old girl...however.i had 2 acres of woods timbered,ive been using"mini-mo" to pull the tops out of woods to sell for firewood.the clutch isnt slipping.when clutch pedal is pushed in to change gears ,i think the throw out bearing or pressure plate or something in there is grinding(can feel vibration in clutch pedal).the noise and vibration is getting more often and its starting to get difficult to go in reverse unless i shut tractor engine off..it will sometimes try and move in direction of gear selected when clutch pedal is in whole way..i tried adjusting clutch pedal.its maxed out.no more adjusment..i aslso greased zerks on starter side.i saw there is a grease line to throw out bearing..i put 3 pumps in it.does it need more grease?or do i need to split tractor to see whats going on in there?nuetral and in any gear with clutch pedal not pushed in,no noise at all.... suggestions???
