Minneapolis Moline Tractors Discussion Forum |
G1000 slight miss
Author |
[Modern View] |
J.A.R
02-22-2021 15:00:04
Had the pump and injectors rebuild by a very reputable company but I still seem to have a slight miss thought it was air in system but after running it for an hour it's not any better. Took valve covers off and cant see any obvious bend push rods. Removed energy cells and they all checked out. It all started this fall was working it on the chisel plow and noticed it had developed a miss when stopped to change a shovel. Put it back to work and cleared out but now it's not clearing up at all. Short of pulling the heads is there a way a guy can measure the lobes on the cam before removing the heads. I'm thinking it's either that or a burnt valve. What's your guys thoughts?
J.A.R
02-23-2021 07:42:19
Re: G1000 slight miss in reply to J.A.R, 02-22-2021 15:00:04
It start as good as any Moline diesel I spose never needed either. It has some white smoke but that went away be4 it started missing.
mmdel
02-23-2021 07:32:15
You can check lobes by taking off the valve covers and measuring the distance of movement of the push rods from 0 down to 0 up. MMDEL
J.A.R
02-22-2021 16:42:15
I did use a infrared gun to check temps on all cylinders and they were all over. None were equal and the temps varied roughly 100* from the coldest to the warmest. I did crack lines individually and it didnt make a noticable difference compared to when I did the injectors on my 670. That part had me really puzzled it had fuel to all injectors when they were cracked and is fresh clean fuel
molinegb
02-23-2021 05:26:07
Re: G1000 slight miss in reply to J.A.R, 02-22-2021 16:42:15
Sounds like time for motor rebuild. Hard starting. White smoke when cold? Cracking lines to detect bad hole not as noticeable on a 6 cylinder.
molinegb
02-22-2021 15:39:03
Any slobbering out exhaust? Crack lines to injectors when running at idle one at a time. Should be noticeable change. Where little change will be bad hole. Check temp of cell caps. Should be equal.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
1935 John Deere BN History - The History of My Tractor - by Alexander G. Knox. My grandfather, Orval A. Knox of Chandler, Arizona, affectionately known as Pa, purchased this tractor new from the John Deere/Caterpillar dealer (now Arizona Machinery) in 1935. It was his first new tractor and his first with rubber tires. He used it on his farm growing cotton, alfalfa, corn, wheat, milo, barley, and oats. My father, Norman L. Knox, recalls Pa putting a mower on the tractor during the day and then
... [Read Article]
Latest Ad:
11-2-34 tires
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
