Need a 1949 R MMoline ring gear--part number RE779
Just heat up, remove and rotate 1/4 turn. Motor fires in same location on ring gear causing bad teeth.
(quoted from post at 15:54:54 02/06/21) Just heat up, remove and rotate 1/4 turn. Motor fires in same location on ring gear causing bad teeth.
Ok thanks for that tip-sounds like a good idea--DF
Can you flip your ring gear over? I did this on my ZA a while back. The teeth on the back side arent beveled so I took my grinder and beveled them.
(quoted from post at 21:08:30 02/08/21) Can you flip your ring gear over? I did this on my ZA a while back. The teeth on the back side arent beveled so I took my grinder and beveled them.
Ok thats a good suggestion--I will be doing the work in the spring--also have been advised to turn ring gear 25 degrees--will see what looks best. Thanks Whiskey
