Minneapolis Moline Tractors Discussion Forum |
Brown belly G-1000
Author |
[Modern View] |
prregld
01-27-2021 18:32:20
I have heard that the early brown belly G-1000's were prone to rear end issues. We bought one this fall that has issues. Just got it running so we are trying to determine if the engine will go to another project or we will try and save this G-1000. After digging into it a bit we can see the ring gear has moved to the left (sitting on tractor direction) enough to not engage the pinion. Is this the typical issue and if so how in depth is the repair? Do the later G-1000's rear end parts interchange? It seems to me there was a dealer recall/fix back in the day but couldn't get any info trying to search it here on the YT site. Appreciate any help. It is a diesel and row crop version. SN: 30600624 I believe.
MinniMan
02-02-2021 10:23:20
Re: Brown belly G-1000 in reply to prregld, 01-27-2021 18:32:20
Hi. We had three G1000's. The diesel had been updated although I am not sure what the dealer update entailed. To mark the difference it had been repainted to the yellow belly. The second one is an LPG tractor brown belly and has never given a rear end problem. Probably less torque on the rear end. The diesel we still have is a yellow belly since it is one of the last ones made.
So if the rest of the tractor is in good condition I would say definitely repair the rear end as they have a low RPM high torque engine and with proper care it will give good service for many years.
The nice part is they don't have a lot of electronics which eventually fail and can be difficult if not impossible to repair or replace. Parts are available new or used in most cases. A lot of HP for little dollars and reasonable on fuel.
prregld
02-04-2021 12:42:25
Re: Brown belly G-1000 in reply to MinniMan, 02-02-2021 10:23:20
This one is in nice shape. Had 23.1x34 tires on it and the guy I bought it from put on 18.4x34's and the cast iron cone hubs for duals. Diesel pump was stuck on it but we had just rebuilt one for our G-1050 so popped that on it and she fired right up. Seat and 3 point was already off it and on a pallet when I bought it. If we get the rear end figured out will probably put o-rings in the scv and 3 point controls and should be ready for haying. We have a late G-1000 wheatland on LP but don't use it much.
prregld
02-02-2021 05:13:10
Thanks for the thoughts. This G-1000 is in such nice shape other than the ring/pinion issue so I hate to not fix it. Will come back with more questions as we get further into it.
Dieselbear
01-28-2021 14:58:46
never had bearing issues on any of mine, but what we found out was the surface that the ring gear bolts to was never properly machined, was not level. Fixed it on two different ones and havn't had any problems just my experence
molinegb
01-28-2021 05:31:30
Was common problem. Heard once it started with bad bearings. Not an easy repair. Tractor has to be split and axles pulled. As with all ring and pinion have to be setup and changed as pair. Know of a new set.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Case Farm Equipment - by Jeremy Sweeten. My name is Jeremy Sweeten and I am currently a junior at Purdue University. I am takin a dual major in Agriculture Systems Management and Agronomy. I am from North Central Indiana, Miami County to be exact. My dad teaches for Marion Community School Systems an outdoor lab called Asherwood. We live there to manage the place. They just happen to have a Case 311 with a Triple Range transmission. I grew up mowing, pushing snow, and hauling maple sap with it. In 1986 my parents bought an old,
... [Read Article]
Latest Ad:
JD starter weights for 10,20 series 75ea JD small green fender toolbox with lid 25 right and left cylinder holders,can ship
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
