Company Logo Shop Now
Minneapolis Moline Tractors Discussion Forum
MM ZB
old weldor
01-01-2021 11:55:11
Looking at a mm ZB the owner says it’s a 1950 but the serial number chart on this site only goes back to 1953. What gives?
shinnery
01-02-2021 00:22:28
 Re: MM ZB in reply to old weldor, 01-01-2021 11:55:11
As far as I know from about 48 to some time in 51 MM included the year in the serial number, right after the prefix. In other words the fourth and fifth digits indicated the year of manufacture.
Bryce
rvirgil_KS
01-01-2021 13:37:03
Tony is correct, people often do not know year of the tractor.
ZB replaced the Z series in 1953. Z series had low seat platform and a hand clutch. ZB had a higher seat platform and foot clutch.
Engine serial plate should be on left side of engine (side opposite the starter). Tractor serial number should be on a plate on transmission case near the belt pulley.
Tractor plate should have 3 letters for model. ZBU, ZBE, or ZBN. ZB is tractor, U is Universal or dual wheel narrow front end, E is Extended or adjustable wide front end, and N is a single wheel front.
If you can get a serial # we can find the year.
MMDan
01-01-2021 13:19:11
ZB was the successor to the ZA and production started in 1953. No engine or drive train differences but lots of operator comfort changes. ZB has raised operator platform with foot clutch, brake pedals on right side, steering wheel in center. Also pressurized radiator and disc brakes instead of drums. Easy to tell the difference if looking at them.
Tony in SD
01-01-2021 12:06:00
It might be a ZA or the owner is wrong about the year, which isn’t uncommon with old tractors. Not a lot of difference between a ZA & ZB. So if it looks good I’d buy it.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
Latest Ad: 560 factory lp has Schwartz wide front new seat all gauges work fast hitch 14.9 38 tires has power steering leak on return side lights work ta works as it should 2 sets rear wheel weights possible trade on other tractors 340 farmall john deeres molines can text pics [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
