Raymond Rauch
With help from Wayne I found a fuel sending unit that I can modify to fit my Moline G900. Now determined the fuel gauge is bad. The replacement past for sending unit was 10a29453. I found in the AGCO books the original fuel gauge part number was 10a29230. Not sure if this works with the associated replacement part for sending unit. AGCO states the part is obsolete anyways. Anyone have an idea where to find one or if this gauge will work with replacement sending unit. Other option would be to find a gauge to match the sending unit. The local shop stated the ohms for the sending unit is 10 at empty and 130 at full. They have tried a couple gauges on hand and nothing worked. One was working backwards and one showed half tank when should have been empty according to sending unit. Thanks for any help given.
