G704 Fuel filters
molinegb
Anyone know whether G704 had single canister filter or two filter setup. GV1 had canister and G705/6 has two. I need to find right one. Every picture different.
It used the early Roosa 2 filter system. First stage was metal canister with replaceable Fram filter inside. Second stage was the throw away metal filter with the glass bowl at the bottom. This system used it's own special bracket that mounted to the water outlet manifold. This system was also used on the G705/6 and MF 97.
