Hi guys, I'm looking for any help or ideas to improve the operation of the front loader on our M670 with the Tel-o-flo system. Several years ago, I installed, what I believe to be, a LS-800 MM loader. The loader is a high lift, so I'm not sure if the 800 would be a high lift or not. Anyway, it is a MM loader that bolted right up to this tractor. After installing it, I realized that the Tel-o-flo system only held approximately 2 gallons of fluid. When the loader is fully raised, the reservoir would be empty, if you filled the reservoir with the loader raised, it would overflow when lowered. I solved this problem by adding an additional reservoir and using a belt driven low pressure pump as a charge pump to keep the Tel-o-flo reservoir full. This worked fairly well so that all of the hydraulics worked like they should. I plumbed the loader into the auxiliary ports of the Tel-o-flo control valve. The loader works, but operates slow. I want to separate the loader from the rest of the hydraulic system by giving it its own reservoir, pump, and control valve. I'm thinking of mounting the pump where the belt pulley would be and using the belt pulley assembly to drive it. I really don't see anywhere else to mount it. Does anybody know of another pump mounting location that would work better? Does anybody have a belt pulley assembly for this tractor that you'd be willing to sell? Thanks for any help.
