59(?) G - PTO question
joejunior
New User
Can a pto be added to this G by removing the plate at the rear differential? What all is needed?
Would there be a lever or mechanism to activate it?
Not familiar with the G, but at Farmamerica we added a PTO to a U. I believe the plate they took off the back was the same as yours. If I recall, it was the PTO unit itself, with the shield of course, plus I believe there was an internal shaft which connected the PTO unit to the gears in the rear end.
Best to get hold of a parts book and verify what you need.
PTO from a U, UB, or GVI will work. Just unbolt assembly from tractor, where yours has a bolt plate. Then reach into rear end and simply grab and pull out the drive shaft. Will fit right into your G. Also a Pto from a Z will work, but the drive shaft will need to be shortened, maybe by a machine shop.
I would have one in Minnesota. As always they are heavy so location would help a lot, not very hard to find parts so closer is always better. You will want the shaft also that goes in the rear end.
