Jetstar transmission and hydraulic fluid
Phil 19
I have a Jetstar and wanted to know is
the transmission fluid and hydraulic fluid
together or seperate? Where is the
hydraulic fluid level and where do you
fill it? Is transhydraulic fluid ok?
They are separate. Depending on what it has for hydraulics/3 point there are different fill places. Most you remove the 4 bolt plate under the seat with the rate and cycle levers. Fill to 1/2" from top. Amplitorc fill plug is on right side, behind and below the adjustment hole (which is the best fill hole for the amplitorc. Rear end level plug is lower and back further behind the brake pedals. Fill from large plug by gearshift.
I am thinking you just fill the transmission to the rear check plug. You can fill through the pipe plug near the gear shift lever.
After you run it a few minutes it will fill to the front check plug at the Amplitorque of its' own accord. It funnels oil thrown from the
gears up through the case to get there.
On my Jetstar, there is a street elbow on the front of the housing and it turns up and has a pipe plug in it. The level in the 3 point is
about perfect if it is brim full there. (Not all jetstars have that elbow on the 3 point and my 445 has none either.)
FILL THE AMPLI-TORC FIRST through the adjusting hole till it runs out of the level plug for that compartment. Then fill the trans diff.
MMDEL
