MM 335 won''t steer
molineman67
New User
My 335 gas, power steering , won't steer. It ran low on fluid then I added, it has a loader, the loader never stopped working but the steering did. It has a suitcase type tank on rear fender. It will steer if I push loader down having front tires off the ground, I did this and steered full range left , right 10 times no luck, tried cracking a line or bleeder at steering pump, no luck. Is bleeding my problem? I would appreciate any help, thanks :(
To bleed steering you need to turn hard to the R & L hold for a few seconds in each direction a few times so the air is forced past the bypass valve to let the air return to the reservoir
MMDEL.
