Company Logo Shop Now
Minneapolis Moline Tractors Discussion Forum
2 Star and Motrac Clutch Adjustment
SWMolines
07-07-2020 04:53:14
I have posted the pages for the adjustment of the clutches and brakes under the original posting from a few weeks ago.
SWMolines
07-08-2020 04:11:00
 Re: 2 Star and Motrac Clutch Adjustment in reply to SWMolines, 07-07-2020 04:53:14
I do not have one of the original fuel pumps. Mine have been replaced with a modern pump.
I do have new seals for my leaking final drive.
molinegb
07-08-2020 05:13:52
 Re: 2 Star and Motrac Clutch Adjustment in reply to SWMolines, 07-08-2020 04:11:00
Looks like major job to change seals.
SWMolines
07-07-2020 11:52:47
2 Stars had electric fuel pumps under their seats.
Did I read you found extra clutch parts? I need to redo the brakes on my bulldozer and plan to do the clutches at the same time.
Still have a final drive seal to replace as well.
molinegb
07-07-2020 15:06:35
 Re: 2 Star and Motrac Clutch Adjustment in reply to SWMolines, 07-07-2020 11:52:47
What kind of pump? Appears to have built in screens. Microfiche shows used in a 504 also. Drive seals leak on mine also. I am going to use heavier oil. Someone had put in hydraulic oil. Drain some out of a U/G and will probably cure leak. Maybe not in your climate.
molinegb
07-07-2020 15:00:44
I found some new clutches. I just used some used ones I had. One clutch was missing a pad and another was not right thickness and was a riveted one. Measured all and setup. Can't really see one wearing the clutches out.
molinegb
07-07-2020 05:54:14
Do your crawlers have an electric pump? Motrac books show a lift pump. Mine has no sediment bowl and books don't show any filtering.
molinegb
07-07-2020 05:05:33
Thanks. Have had all apart. Changed couple clutches. Cleaned and adjusted. As with most there is tricks to working on them.
Copyright © 1997-2020 Yesterday's Tractor Co.
