crashman111
I have a late model (1969) M670 Super. Within about 20 minutes in the field, all of my power steering fluid is gone from the reservoir, obviously leaking out from somewhere. Problem is, I have traced as many lines as I can find and am unable to determine where it might be leaking. Is there a common place on these steering systems that leaks after years of use? Some specific place I should be looking for the likely source of the leak? The pump does not seem to be making any noise, I just get to a point where steering becomes difficult and I'm either really low, or out of fluid.
Any and all suggestions would be very much appreciated.
Thank you.
Thank you.
