Minneapolis Moline G900
Working on a MM G900. Throttle moves back to idle after moved forward to higher RPM's. I am assuming parts in the throttle control need replaced. Removed top Star nut and found what looks like a friction disc and large washer on the bottom and a small washer on the top of the unit. Next to it was a spring and small ball bearing that slid in the groove of the throttle plate. Is this all that is supposed to be there and where can I find parts. If someone has a diagram I would appreciate it. Thanks
If you take it all apart and have it moving freely, reassemble it. The outer clamping but adjusts the tension on the friction. They get worn and need to be adjusted tighter, but are usually rusted tight and need to be all freed up first.
