M5 Front rims
molinegb
Anyone have a picture of M5 front rims with adjustable front axle? Have piles of rims but none look right. U,Z same or?
(quoted from post at 13:11:11 05/08/20) Anyone have a picture of M5 front rims with adjustable front axle? Have piles of rims but none look right. U,Z same or?
(quoted from post at 18:35:41 05/08/20)
(quoted frm post at 13:11:11 05/08/20) Anyone have a picture of M5 front rims with adjustable front axle? Have piles of rims but none look right. U,Z same or?
Thanks. Have several of those rims but all mine standard axle so offset different. Standard rim won't work. need measurement from outside of rim to center, Standard like 2 inches and tire rubs.
Flip the hubs around, that gains about 2" and opens up a lot more possibilities for wheels on the front. The race od is the same for the inner and outer bearing, so you swap the races to flip the hub around.
My wide front '65 MM M670-LP needed new tires on the front shortly after I bought it. I found 2 similar tires and wheels on eBag and bought them. When I went to install them they rubbed on the inside so I turned the wheels around and bolted them on backwards. No problems since. They are a multi-rib general use tire but it steers fine.
Looks like what I tried on mine. Have 5 or 6 M5's but all standard with 7.5 x 16. They rub. Have about 2 inch offset. U302 same as
is also standard. Every other tractor has rims on backwards to make fit. Have couple 670's but won't fit as standard also. Must be
1 inch offset difference. Thanks. No tractors around here with adjustable front ends.
Like to keep original. Didn't think finding a couple of rims would be so difficult. Think have 4 with wrong or backwards rims. No
idea where all originals went to!
Measured bunch of rimms. Most here are 1 x 5 on standards. Have one on a late UTS and is 2 x 4. Adjustable must be 3 x 3. with 6 16 tire? Standards are all 7.5 x 16.
These are 7.50s, but the original one were 6.50s or 7.00, I think one size narrower than the 7.50. I replaced the ones on the M5 with 10.50 X 16 three rib. You can't get your little finger between the tire and spindle on this one. It had 6.00 X 16 on when I got it.
