MM 110 Lawn Tractor Deck Drive Belt Number
SWMolines
All,
I have a MM 110 with the 36" sheet metal mower deck. I am looking for the modern day number for the v-belt that drives the mower deck. Can anyone help me out?
If not, I can pull it and get it measured. It would be nice to have one in hand when I tear into replacing it.
The NAPA dealer up here used a timing belt off an automotive engine, it worked, dont know the number, I'll try to get it if you need it.Ive got 7 or 8 decks here, need a used one in good shape?
Thanks John. I have a good replacement for the "Timing Belt" that runs between the spindles. The one I am researching is the the v-belt front the engine (electric clutch) to the left hand spindle on the mower deck.
Thanks John. I have a good replacement for the "Timing Belt" that runs between the spindles. The one I am researching is the the v-belt from the engine (electric clutch) to the left hand spindle on the mower deck.
Doing well. How is the book of a 1001 shop tricks coming along? You should have plenty of stay-at-home-time to get it all written. Maybe even add a few illustrations?
I'll call you on the belt. Do you have the one for the starter/generator as well?
Might have, Inventory says I do but number on belt in stock doesn't match up. The belt in stock is 31 1/8 " outside dia. Width is 1/2 plus 1/32". Looks to be the right one, check your old one.
MMDEL
I'll look at it when I get it out in a couple of weeks. I do not believe the gen/starter belt is 1/2" wide. It will be narrower than that
