MM G1000 wiring
Thanks for the replies, the mystery wire was for that Aux hook-up. If my bother you with another question, I see the fender headlights are fed with one wire; one wire to both headlights on each side. The work lamp in the left hand side fender is fed 2 wires. For what purpose?
Thanks,
CC
I have a 302 diagram. The 2 wires go back to light switch, one to TL (Tail light) and to FL (Flood Light) or working light.
Thanks Virgil. The diagram in my G1000 parts book doesn't indicate any switch, maybe I need to study the parts listing to see if a switch is listed. There's but one lamp in the back, referred to as a flood, bulb no. 4428?
C
Switch is four position switch. Battery,dash light to transformer,headlights,rear light and work light.
