ZA Hydraulic Lines
We just got our ZAU back from having the local FFA ?restore? it (not perfect by looks great to my dad and me!). In order to get the original hydraulic hoses out of the block that bolts to the pto lever bracket, they had to heat the block. In doing this, it has caused the lines to leak on the back of the block. Does anyone know how to repair them?
The tubes are silver-soldered in. (The 1200 degree stuff, not the 'silver-bearing' solder.) I don't know if you can just heat them back up and solder or if you really need to heat them, get them apart, get all the oil off and clean everything squeaky-clean, the block as well as the tubes and then silver solder.
I was always replacing the tubes when I did that, so everything was clean.
