Company Logo Shop Now
Minneapolis Moline Tractors Discussion Forum
rvirgil_ks
pa don
03-22-2020 06:46:34
would you post a view of gen. to alt. conversion thanks
Rich'sToys
03-23-2020 22:08:52
 Re: rvirgil_ks in reply to pa don, 03-22-2020 06:46:34
One thing I did is; the wire with the diode on it--instead of running that all the way back to the ignition switch, I just ran it to the + side of the coil. Same connection, just used a lot less wire!
rvirgil_KS
03-22-2020 08:15:13
Is this what you are wanting?
pa don
03-23-2020 10:10:01
 Re: rvirgil_ks in reply to rvirgil_KS, 03-22-2020 08:15:13
what do you think of the one wire alt. is it a simpler and easyer way to do
rvirgil_KS
03-23-2020 14:34:36
 Re: rvirgil_ks in reply to pa don, 03-23-2020 10:10:01
Yes, the 1 wire are simpler to install.
But I agree with OLD. I prefer a 3 wire for the reasons he has given. I have 2 tractors that came with 1 wire alternator and I converted them both to 3 wire buy changing the regulator.
A person's wiring knowledge and skill are often the determining factor in the choice.
If it works, that is what matters.
old
03-23-2020 10:46:33
1 wire is easier but it has its draw backs. #1 most take a high RPM to self excite.
#2 some are also known to cause a battery to drain over a long period of time say if it sits a month.
I only have one tractor with a 1 wires all the rest are 3 wire. The 1 wire will charge when it wants and then not charge the next time I use the tractor or start charging after it has run for 15 plus minutes. Plus the 1 wire cost twice what a 3 wire does
Copyright © 1997-2020 Yesterday's Tractor Co.
