I have a 5 bottom MM plow, but need to check the model, but it has a single moldboard that bolts on to make it a 6 bottom --- will check the model designation.
Steel wheels and levers.trip so probably early 50's.
Thanks for comment. Mine is definitely MM, but later model and in snow drift. I have operators manual S-401 on mine which is a D-400 series, but do have a 3 bottom trip lever and a disc plow (which works well in prairie sod.
Very few disc plows here mainly all oneways or wheatland disc plows. Disc plows didn't work in our heavy land.
Took me a long time to find an FF. I was able to pick up a 5-16 rope trip. Have seen a couple of 14s in my travels but this is the only 16 that I have seen. The AFs are fairly common around here but the DFs are even tough to find.
(quoted from post at 17:30:37 02/14/20) Steel wheels and levers.trip so probably early 50's.
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto5145.jpg">
Yep Molinegb that's it, I bought one of the last ones in Dec of 1957. It was Hydraulic, on rubber, had throw away shares, and rear tail wheel lock.
MMDEL
Nice find MolineGB! Been trying to find a five on steel w/trip for my TC's. Didn't use that big of plows in my country with rocky sugar sand and small farms. Lots of 1&2 bottoms. Envious.
