Company Logo Shop Now
TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Re: M670 super doesn't move
Rbear
01-14-2020 20:38:05
Ok today 1/14/20 Temp 62 started engine left run for 5 minutes with clutch out. Pulled amplitorc to low range and shift to forward gear & release clutch just some low metallic noise no power/movement reverse same. Shut off & remove transmission cover and start engine. When clutch depressed no metallic noise, sliding shaft & gears slow to a stop, shaft under that, I guess the clutch shaft, continues with power. Metallic noise returns when clutch is left out at friction point and sliding shaft & gears start turning again. Clutch depressed & amplitorc pulled to low and same thing repeats. Gears look good in transmission. Metallic noise seems to come from in front of trans in amplitorc sounds like teeth sheared off & smooth pipe or metal rotating on ruff edges.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
