Quick attach loader.
Joe Pro
Has anyone put a different loader other then the MM L800 loader on a JetStsr or U302?
I need to upgrade loader tractors.
Been thinking maybe I could use one of my U302s with a different loader
Woods
Westendorf
Ford
I'm thinking I could put a hydraulic pump from a big mo on to better run it.
I've had a Westendorf WL-21 on my U-302 Super for many years and would highly recommend it. Right size for the tractor, easy to take on and off and works fine with the Tel-O-Flow system IF it full of oil. Mounting brackets are available from Westendorf that fit and are easy to install.
I have a 302 with a 146 john deere loader on it. This is the second 302 it has been on. Had to drill some hole in the side channels but it works pretty good. It uses the tractor hydraulics. Plumbed it to the pump so the remotes are not tied up.
