4Star Loader
J.A.R
Just curious on how much this tractor could or should pick with a Oliver/Schwartz 1510 Loader tapped into the original hydro system using the factory levers.
It does have a wide front. I want to use it for moving 5x5 round bales so I dont have to move skid loader back an forth. But if they break doing that I'm sure they will break moving bales. Looks like I'll have to use it as a toy thanks for the input.
I have a Jet 3 Super which has a very similar front axle. I move 5x5 bales with it every year. I usually move two at a time with one on the back & one on the front. The one on the back helps to counterbalance the one on the front some. Have never broken a spindle hauling bales but have broken a couple over the years hauling buckets full of dirt.
Just to add, if it is an earlier system (one hydraulic line coming out of the hydraulic pump) I
wouldnt strain it too hard. The 4 Stars with the later external plumbing were better systems.
