Company Logo Shop Now
TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
G706 timing
Plowhand
11-23-2019 07:43:18
I have to take off my injector pump what is the best aproach for ease of installation after pump is repaired..
molinegb
11-23-2019 09:44:05
 Re: G706 timing in reply to Plowhand, 11-23-2019 07:43:18
Line up flywheel marking btdc with line in window of pump.Remove and install without moving motor.
Plowhand
11-23-2019 10:25:03
 Re: G706 timing in reply to molinegb, 11-23-2019 09:44:05
Does no.1 piston have to be in compression stroke?..IT manual says 9 that is before top dead center correct?..thanks
Dieseltech
11-23-2019 14:18:17
 Re: G706 timing in reply to Plowhand, 11-23-2019 10:25:03
Yes, # 1 on compression. Align the two marks under the pump cover, then see where the flywheel is. If you align the flywheel first there's a 50/50 chance whether pump will be in time because pump turns 1/2 engine speed.
Copyright © 1997-2020 Yesterday's Tractor Co.
