5 Star Tach
Unscrew the round nut on the cable. Might have to hold onto the cable housing just behind the nut with pliers, and use another pliers to unscrew nut. The 90 gearbox should come off with just unscrewing other nut.
The darn cable won t come out of the housing. I ve removed the adapter from distributor. I don t want to damage adapter.
Ok. Cable is out of tach, all I have now is old cable with 90
degree adaptor hanging on the end of cable. Seems like
cable should pull right out of housing. Wrong!
Does the cable rotate in the housing and the adapter. Can you rotate from ether end. If not the cable is probably twisted off somewhere inside and wadded up. However you should be able to pull the cable and housing off the adapter if the cap is unscrewed. Submerge the end of cable with adapter in ATF, penetrating oil, or your favorite solution. for a week or so.
MMDEL
