Duane Kaufman
Dear Forum Members,
I have an idea rolling around in my head based on a rear-end from a Constellation series tractor (335, 445, 5-Star and derivatives), that requires a mechanical link-up to drive the pinion shaft from the outside of the transmission case.
I do know what the overall geometry of the pinion drive and differential cage looks like (but not specific dimensions). I'd like to couple to the brake-pad end of the pinion shaft to drive it, but retain the braking system as well.
An image of the part I would want to drive is here:
(Image from: https://www.ebay.com/itm/NEW-OEM-Minneapolis-Moline11A8248-rear-end-Gear-for-M5-M602-PKG55-5-Star/323692291452?epid=11023524092&hash=item4b5d90657c:g:WhgAAOSwUvVcYxsN:sc:FedExHomeDelivery!53544-9354!US!-1)
My question is, what is the diameter of the pinion shaft on the brake-spline end (say, on a 335), and do these part diameters get bigger with the bigger tractors (G1000)? If the parts change size, does anyone have dimensions of brake pads from a 335 and from a G1000 (both inner diameter and outer)?
I _do_ have a 335, which I could open up to measure, but I don't have a big tractor, like a G1000.
Appreciate the help,
Duane
Ebay link
Duane
Ebay link
