Any luck advice on restoring a rtu/rtn?
I inherited a mm rtu/rtn not sure what it
is exactly I can't read the serial # tag
as its been outside forever. I just found
the hand crank and after a few MMO
treatments prior the motor is not stuck😇
I seen the radiator is leaking and lots
of animal nests in it. I did a search of
MM PARTS online and eBay and it seems
these tractors are hard to find parts
for. I love the prairie gold and red
paint schemes. Any advice on how to
proceed if at all. I see all kinds of old
and impossible rebuilds on classic
tractor fever but I'm fairly novice at
this. I know the motor was revolutionary
at the time being an ohv engine. Thanks
guys!
(quoted from post at 18:35:53 09/03/19) I inherited a mm rtu/rtn not sure what it
guys!
A lot of R parts out there. The problem is unless it s sentimental to you in the description you provided it s a money lose.
Where are you from? Radiator is not the most economical thing to ship but I have a couple. R parts are not difficult to find if you know where to look. Just not much out there for new aftermarket like there is for an 8N Ford. RTN is single front wheel, RTU is narrow/tricycle front.
Parts are not a problem, you just have to search for them. They are easy to work on. Just bear in mind that you can put a lot of money into it and never got it back if you sell. You Got to remember it is a hobby. Since you inherited it, you must have some sentimental interest in it. Good luck!
Don't be too quick to judge, radiator may be repairable at a lot less cost than another used one. Bring it to a radiator shop for evaluation, might save a bundle.
I'm from michigan. Damn thing is
sentimental to say the least. I see sweet
ones for 2000$ good enough for a parade
or a lawn ornament lol. I was thinking if
the motor was stuck I would just swap out
the sheetmetal and a few parts just to
have a sentimental Frankenstein rtu lol I
always heard the hand clutch is a bit
tricky and dangerous
Its just something about that harvest gold and prairie red that draws me in. I'm not partial to any specific manufacturer but those 2 colors are a thing of beauty. i have a MM rtu needing a full restore
I had no problems finding parts. I did 2 One for a friend and this one for Me.]
