Gas carb on LP GTB
Will a gas carb bolt up to LP intake on GTB...thinking of putting a gas carb on my GTB until I can get the LP system figured out...any recommendations as to what will work...have seen some tsx-67 for sale if it will bolt up to LP intake. Thanks for any replies.
Yes TSX 67was common on the U. Will bolt straight up. Common carburetor for GTB is TSX68. Basically same as 67 except for venturi. Throttle linkage on opposite sides between 67 and 68. Not sure which side the lp is on. May have to redo governor linkage
