Minneapolis Moline 800 vs. 800HD
Links56
New User
Does anyone know what the differences are
between the straight 800 CID and the 800HD
motor? I know the blocks on the HD have
studs verses bolts through the bottom but
what else is different and do the parts
interchange? Thanks.
Several differences , adding up to significant increase in power for the HD. COMPRESSION INCREASE, square port heads, better manifolds to list a few.
As far as the internals like crank rods etc are the HD parts the same as the straight 800? Can you put HD blocks and heads on the straight 800 crankcase? Thanks I appreciate the info?
