Spin on oil filter for MM Z
DIM
If you put a spin on filter on a MM Z-R do you have to use a filter without the back flow valve
The answer to your original question is yes. The filter must have NO drain-back valve.
The oil actually goes through the filter backward from the designed normal flow direction and a drain back valve will stop the flow.
