G706 brake discs
plowhand
I took apart my brakes they were seized got em working lot of meat left on discs I cleaned everything up with wire brush they dont work that good have to stand on brakes to get any stopping power.
As far as I know I set the brakes up there is resistance there I have discs in right position.zIs there a way to put the actuators in backwards?
Couple things. If you want them to work like they were new, have all the braking surfaces re-surfaced at a machine shop. It's the same as having a flywheel re-surfaced. The other thing is that disks have a tendency to become oil soaked. If that's the case, you can gain some ground by teasing them with a torch to flash off the oil and grease.
