Anti freeze in crankcase
Nebr. MM
I'm getting some anti freeze in the crank case of my UB. Is there any other way it can get there other than the head gasket?
Water pump drive can leak into crank case. On a GVI, I removed the oil pan and inspected to find water dripping from gear that drives the water pump.
In my case with the GVI, the weep hole area of the water pump was severely pluggged and would not let water escape. I had to remove water pump to clean and reseal.
Most likely place is the water pump. Specifically, the water pump weep hole. It's probably plugged up with grease and dirt. Clean it out good and see if your problem goes away.
