Company Logo Shop Now
TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Anti freeze in crankcase
Nebr. mm
07-09-2019 07:02:13
I'm getting some anti freeze in the crank case of my UB. Is there any other way it can get there other than the head gasket?
molinegb
07-09-2019 17:41:31
 Re: Anti freeze in crankcase in reply to Nebr. mm, 07-09-2019 07:02:13
You can inspect for seepage through handholes. Antifreeze has to be dripping down.
mmfan55
07-09-2019 14:58:25
Water pump seal, head gasket, cracked head or jug most likely suspects
Ronnie Budd
07-09-2019 14:10:39
Most likely place is the water pump. Specifically, the water pump weep hole. It's probably plugged up with grease and dirt. Clean it out good and see if your problem goes away.
jnf
07-09-2019 08:07:23
In my case with the GVI, the weep hole area of the water pump was severely pluggged and would not let water escape. I had to remove water pump to clean and reseal.
jnf
07-09-2019 07:25:32
Water pump drive can leak into crank case. On a GVI, I removed the oil pan and inspected to find water dripping from gear that drives the water pump.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
