I am restoring a '47 R with my grandson. It has always had oil pressure - as indicated through a cloudy, decrepit gauge - and we have driven it quite a bit since we got it started after probably 10 years of inactivity. By driven quite a bit - I mean we have driven it at least 25 miles. Now we have new gauges installed and realize the oil pressure is pegged at the top of 50 psi on the gauge. I have turned out the oil pressure adjusting screw several complete revolutions and it does not seem to make any difference. Any suggestions? Is this a serious problem? Occasional trips down the road are all that are in the future for this tractor.
Also - this tractor has a distributor - not a magneto. All battery connections - including the starter - were missing when we got the tractor. We have it set up with a 6v battery and a negative ground. Is this correct? It has a generator. Everything seems to work fine. Now showing my tractor/mechanical ignorance - what was the reason for using a positive ground system in the first place?
