Moline R parts book help
JOCCO
I am looking for parts manual for the r tractor Need the early one and all I can find is the later ones like 1951. Or do they combined all in one, thanks
You probably need a R1006 series r parts book, the R1006D and E books are the old small ones, R1006L is the newer bigger size and might do you depending on your serial number, R1086C covers the newer Rs with the square hood and smaller disk brakes, hope the numbers help you out.
there is a service manual for the older R series at nnalert(dot)com
Click on tractor forum scroll down to user manualsMM tractors scroll clear to bottom for R service manual. scroll down to attachments and click on blank icon to download
Also newer parts manual you mentioned
I am thinking the Museum in Minnesota can help you with a reprint. They got a lot of the old MM paperwork after MM shut down.
Perhaps someone can help with an address. It probably has a website, too. Its something like 'Floyd County Historical Society'.
Not really many differences in the 3 generations of R's. Smaller clutch in first ones but besides tinwork most same. What year?
Knowing the serial# would make this process easier as the correct book is generally identified that way (not the engine serial#). Look on right side of transmission for the tag.
