Company Logo Shop Now
TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
JD hydraulic cylinder used on MM U
dfarmann
06-11-2019 13:38:35
Somewhere I thought I read where there is a hydraulic block that will allow MM hydraulics to use a normal hydraulic cylinder.
If I'm correct would someone be more specific with a manufacture part number and possibly a retailer. Thanks.
molinegb
06-13-2019 15:52:28
 Re: JD hydraulic cylinder used on MM U in reply to dfarmann, 06-11-2019 13:38:35
I am thinking some of the JD cylinders had locks also.
minniemo705
06-13-2019 10:43:35
Just put a simple hydraulic check valve on the line that holds the cylinder in the up position. You only need the one. It cost about $20 at my local hydraulic shop. I have it on my MMG. Makes any non MM cylinder work like it should.
Alan K
06-13-2019 10:28:01
The Uni-matic systems that were used on MM models up until 1958 needed an MM cylinder with the lock out feature. Starting with the 335 and 445 models in 1956 on up with the new hydraulic system you could use any brand of cylinder.
Jr1983
06-12-2019 03:51:27
One of mine has had the one way valve switched put for a regular two way open center valve. That works good.
jnf
06-12-2019 03:44:18
Northern Tool has a 4 port Lock Valve
Model #408-04
Item #2070
1-800-838-0516
JK2
06-11-2019 20:36:40
Search google for the following line & several will show up.
Double Lock Valve hydraulic cylinder
Click the link for a description of one of these.
Shaun Wallace
06-11-2019 13:46:56
All I have ran on the 5 star I have has been just plain ole cross or prince tiebolt cyl in 3 1/2 or 4 inch. Have had no problems other than settling from worn hyd componuts.
tony in sd
06-11-2019 18:06:07
 Re: JD hydraulic cylinder used on MM U in reply to Shaun Wallace, 06-11-2019 13:46:56
Not sure when MM changed from locking to non-locking but the Star series I drove did not use the locking cylinders of the early letter series. As far as I know you have to have an MM locking cylinder to work on the early letter series. I am not aware of any others that will work.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
