UB Special/Five Star wide front swap
I think it will....check to see where and how it fastens to the tractor..but if its held to the front of the tractor with 4 bolts and the steering arms are held in a wedge with 1 bolt then I think it works
Special mount.
I am referring to a row crop wide front off a Five Star, not a standard wide front. I have located one, but it is two hours away and I want to know if it works before I make the trip. Thank you for the replies.
Row crop or universal is adjustable same mount as E configuraton. No standard ever on a UB. Mounting same as the UB I posted
picture of. Axles probably same but mount not as Special bolster made with power steering cylinder. Very few 5 Stars were
standard.Let me know what you are trying to do as have all parts books. I can compare as have both here.
I am wanting to remove an adjustable wide front from a Five Star and install it on a UB Special that has factory power steering.
UB special has a 4 5 inch drop in spindle that connects to steering rod. UTS Special has even less chance.
chance.
Got a message from Marty Mohr today. They have a UB Special with the tubular wide front axle. Looks like the 5 Star mounts bolt right up to a Special.
