NI 501 loader on a 670?
sam c
Is it practicable (anything is possible, with enough money) to put a NewIdea 501 loader on a M670 Super? I am concerned about the pin that holds the front end in place. I have lost the front pin twice and reinforced the assembly holding it in place. It is holding but a loader is a greater challenge.
Other possible tractors are: Moline ZAU, Moline UTS, Allis WD-45 with Swartz front end, IH 424, Allis D-15.WFE
Thank you for your experience and advice
Wash, Clean everything on both sides. Then run engine till it starts to leak. Watch close so you can see exactly where it is coming from.Check highest points first. Don't need to take something apart and then find out latter the leak was in a different place.
MMDEL
We had a NI-501 on a M-602 and then I put it on a Super U-302 and the only changes assuming you have the whole mounting mount was how it fastened on the back axle. The only problem I seen was the loader gets close to the front radiator housing when it comes up stuff on the bucket is close to the tractor. Is the 670 longer than a M-602? Our NI-501 loader was all broken up and reinforced over & over that the more powerful tractors pretty finished destroying such a light loader and I hooded some junk on the front of the tractor and broke the casting. From what I read the NI-501 loader was designed more for WD and WD-45 Allis Chalmers or that size range??cleddy
Thank you, I think you are correct. I will look at my D-15. It has power steering or the IH 424
