Company Logo Shop Now
TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
UB Exhaust Manifold Replacement
MnBoy
04-18-2019 20:00:26
My '53 UB has huge cracks in the exhaust manifold. Didn't help when I created huge backfires when I went to new Pertronix, dist. cap, wires, plugs, then reconnecting the wires incorrectly. Didn't realize that the rotor moves counter-clockwise. Anyway, I have ordered a replacement exhaust manifold and want to know if anyone has done this and if they can offer any advice. Thanks.
molinegb
04-20-2019 11:00:51
 Re: UB Exhaust Manifold Replacement in reply to MnBoy, 04-18-2019 20:00:26
1938-41 U will fit but smaller throat. 1942-57 U or UB all same. M5/M602/M670 336 gas will also fit. All 21-32/FTA/Gt/GTA/GTB with 403 motor also. Some new Chinese manifolds one have created issues with governor.
MnBoy
04-20-2019 10:17:04
Very creative to use a number of different manifolds on the old MM's. I have to try attending a swap meet if possible. Thanks.
Rich'sToys
04-20-2019 09:57:16
I picked up this manifold at the Le Sueur swap meet years ago. Not sure what MM tractor it originally came off of, but I put it on my UB and it works great.
My other UB and my UTS both have this manifold:
george md
04-19-2019 20:35:26
If you want black on the hot parts , get a can of JD muffler painy.
You won't like the price , but it will last better than anything
else. I hate buying JD stuff ,but it works.
george
george md
04-19-2019 20:29:01
I have repaired MM manifolds that were worse than that. Don't do it
much anymore ,health is catching up with me.
I'll put a link to a Mm I did a number of years ago. Tour the whole
site.
george
Dennis P
04-20-2019 08:16:54
 Re: UB Exhaust Manifold Replacement in reply to george md, 04-19-2019 20:29:01
What did you use in the weld process?
george md
04-20-2019 11:41:33
 Re: UB Exhaust Manifold Replacement in reply to Dennis P, 04-20-2019 08:16:54
Dennis,
The rod is cast iron in stick form ,use with flux and oxy/acet
torch. Preheat as necessary ,shapes are not bad to weld, flats you
will preheat and post heat or they will crack.
There are many more photos in imageevent , take the tour, click
on thumbnail and it will go full size ,click again to return to
thumbnail.
george
http://www.imageevent.com/gmachine
MnBoy
04-19-2019 22:34:55
George, the job you did on the "cracked beyond recognition" manifold is amazing! Like a piece of art when you finished with it.
mmfan55
04-19-2019 17:56:48
Usually if nuts don't want to turn: the stud will screw out. Yours don't look too bad. Should be an easy swap
Bob M
04-19-2019 16:18:38
Replaced a cracked manifold on my '47 UTU (same engine as your UB).
Had no issues whatsoever changing it out. The clamp nuts (brass) came off easily, and the new manifold fit up perfectly.
I didn't bother painting the new manifold. It came painted, and the original manifold lasted 60+ years with the OEM paint - that's good enough for me.
MnBoy
04-19-2019 22:32:01
 Re: UB Exhaust Manifold Replacement in reply to Bob M, 04-19-2019 16:18:38
Good point about the original paint!
MnBoy
04-19-2019 08:42:28
Thank you for the reply. What kind of paint did you use? Also, did you have any issues removing the [rusted] nuts? Looks like they are originals. Here are some photos.
Scout2008
04-19-2019 11:00:37
 Re: UB Exhaust Manifold Replacement in reply to MnBoy, 04-19-2019 08:42:28
No, the nuts came off pretty easily. I usually replace them, and the studs if they are worn. That thing is really cracked! I used high temp primer and paint and it didnít work well. I have been having the ones I have done lately cerekoted.
MnBoy
04-19-2019 11:29:06
 Re: UB Exhaust Manifold Replacement in reply to Scout2008, 04-19-2019 11:00:37
Scout, thanks for the input. Yes, that manifold is "toast." I did look into the cerekote process, a ceramic-type coating. Not cheap, but likely the right system for superior results. I am guessing you do a fair amount of work on Vintage Tractors. My UB is just a workhorse, used to move stuff around with a front loader.
Scout2008
04-20-2019 03:41:29
 Re: UB Exhaust Manifold Replacement in reply to MnBoy, 04-19-2019 11:29:06
My UB, was my Grandpas and he bought it in 54.
Scout2008
04-19-2019 16:13:48
MnBoy
04-20-2019 07:59:02
 Re: UB Exhaust Manifold Replacement in reply to Scout2008, 04-19-2019 16:13:48
My grandpa and dad both worked at the MM Plant in Minneapolis on Lake Street. I have a picture of grandpa [top row, second from left] at the Lake Street Plant. I grew up in Minneapolis not far from this Plant.
MnBoy
04-20-2019 10:41:08
 Re: UB Exhaust Manifold Replacement in reply to MnBoy, 04-20-2019 07:59:02
Trying to send a better picture of grandpa at the Minneapolis MM Plant on Lake Street.
MnBoy
04-19-2019 22:37:20
Scout, yes I did see your post earlier. What a masterful job you did on that UB!
Scout2008
04-19-2019 06:46:35
I put a new one on my 53 UB a couple years ago. I put an electronic ignition in it, and the new manifold when I restored it. Everything works great. Biggest issue if getting a good paint on the manifold to fight rust.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
