Company Logo Shop Now
TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
MM rtu issue
Grandpa love
04-14-2019 19:05:26
Couple weeks ago we were driving it and float stuck in carb. Flooded it good. Got that resolved and now the tractor is back firing and not wanting to idle good. Tinkering with it the other da myy and with out touching the throttle,while I was adjusting the carb the motor revved WAY up. Turn carb back other way and it didn't slow down. So I killed it. Waited a minute or two and crunk it up and it was running at proper speed but still rough. Any ideas? Does governor need oiling? Thanks.
Dennis P
04-15-2019 18:14:18
 Re: MM rtu issue in reply to Grandpa love, 04-14-2019 19:05:26
I rebushed my governor & repaired the throttle shaft area where the shaft goes through. My ZTU works as smooth as any. My RTU did as you were saying, did the same to it, works smoothly now. On my Z, I filled the hole on the linkage side with JB Weld & cross drilled it. If you do it this way & it isn't straight, refill and try again. It has been this way since 2001 & runs like new. Just my two cents.
unc
04-15-2019 16:33:47
Just a shot in the dark- check that the governor linkage to the throttle is loose and works freely. You can loosen the nuts that hold the carb to the manifold flange, and move the carb body around a little if the linkage is binding. You can put a drop of oil on the contact points of the linkage as well.
I've tinkered with the governor, carb, and linkage on my ZTU, but I've never gotten it to really snap open and shut like the ones on the U models. unc
morepower02
04-15-2019 16:33:19
Start with the basics:
Compression
Fuel
Spark at the right time.
If the above are good I would rebuild the carb and you should be good.
Grandpa love
04-15-2019 15:33:48
No ideas? Anyone? Thanks
Jocco
04-15-2019 17:39:49
 Re: MM rtu issue in reply to Grandpa love, 04-15-2019 15:33:48
Definitely linkage if you have tinkered with carb. Sucking air around throttle shaft, gasket leak. A condencer can cause issues to.
