I had the Vickers hydraulic pump rebuilt on my 69 M670 during the restore. I hooked everything up, and everything was working good. I had to drain the system, and upon refilling it I have a lot of noise in they hydraulic system. At first I thought it was air in the lines, but I have gone through the whole program of bleeding it and even have the hose in the remotes to run fluid through there. The line coming from the pressure side seems to have a lot of high frequency vibration when not raising the 3 pt, or when the by pass hose in the remote is not open. It did not do this the first time I filled the system. The vibration can be felt under the platform under your right foot while sitting on the tractor. I hope I have described this well enough for someone to possibly have some answers. Thanks!
