605 flywheel
mmkid
Got a newer 605 with 4231 heads, I think a 605b with a real ugly flywheel and am having problems with removal. Any ideas to get this thing off? Thanks
Are the two extra holes threaded, matching the bolts that hold the flywheel in place? Screw the bolts in and push the flywheel off.
as said , feel with a small punch if you are able to use a couple push bolts to remove it.
I usually pull the starter and use a big drift and heavy hammer and just keep tapping and turning the engine a little bit and keep going around,I've never had one that didn't come loose doing that
