Dennis P
I am having a problem with my KT clutch. If I engage, tractor will pull & operate normally. But, it will "fall" out & disengage shortly. The only way To keep it going is to put pressure on the handle. I adjusted it like the manual says, but same thing. I can pull the side plate & watch the clutch cone engage the fingers & it looks to be going in all the way, just like the operating manual shows. When it is engaged, what keeps the fingers from sliding off the cone? Is there supposed to be a groove on the cone high side to hold fingers in place? I get how the later style works, but how does this one work or just worn out?
