Minneapolis Moline Tractors Discussion Forum
Re: MM U Cylinder head Casting #’s
mmfan55
01-29-2019 15:07:23
4210 will work but will need shorter head studs and pushrod. May also need spacers under water manifold to line up to radiator. 4210 is a higher compression head than 30E and not as thick. You will see the difference in thickness on the chart suggested.
Ill John
01-29-2019 15:33:59
 Re: MM U Cylinder head Casting #’s in reply to mmfan55, 01-29-2019 15:07:23
There was a kit of spacers made to do this change. Have to look hard to find one these days.
