Project pics
Scout2008
Figured I would share pics of my cold weather project. Tearing down the engine on the 70 U302. All original parts, never rebuilt. Hour meter stopped with 3700 hours. Everything in good shape just will need to go 20 over in the cylinders. Also put new rims and tires on the front. My plan is to go through everything mechanical this winter, run it during the summer to make sure everything is good, and restore next winter. Not quite done with the 69 M670 restore. Unfortunately I have to split it to fix a A/T seal leak...after it's been painted. Going to have a bunch of paint to fix.
Does that 302 have flat finders on it like a late model 670 with closed center hydraulics. If so does the 302 have closed center hydraulic system on it.
The 70 302 is different from the others due to the flat top fenders, and an external steering cylinder under the frame on the right side. Also they used a different suspension seat.
