Purchased a 1947 RTU about 12 years ago. Converted it from the 12-volt system previous owner had made, back to a 6-volt system. The tractor
is NOT exposed to the elements and is always inside a heated shop. The tractor will not spark or ignite. I have tried various things over
the years, without success. This tractor will NOT spark. Here is a list of what I have done:
New battery & battery cables
New correct custom-made wiring harness
Rebuilt carburetor (tractor ran good after that for a few months, then without any changes, simply would not start again & hasn't since)
New spark plugs, properly gapped
New spark plug and distributor wires
New coil
New distributor cap
New condenser
New dust cap
Cleaned & re-gapped points
Cleaned all electrical connections
There is electrical power to the starter, the coil and the distributor. The tractor will crank all day long, but will not even attempt to
spark or ignite. Pretty frustrating.
I am looking for any and all advise or suggestions. I look forward to hearing back from folks.
Thank you in advance!
JKC
New coil
New distributor cap
New condenser
New dust cap
JKC
