1948 GTB transmission/rear axle oil
Elly
New User
Hi,
I'm enquiring as to were the oil drain and filling point for the trans/rear axle are located and the type of oil used.
Thanks
David
There is a plug for draining on the bottom of the rearend housing which is often hidden by the drawbar. 80/90w should work unless you are going to do
heavy work. then 140w.
(quoted from post at 20:26:53 01/17/19) There is a plug for draining on the bottom of the rearend housing which is often hidden by the drawbar. 80/90w should work unless you are going to do
Thanks. Maybe silly question but where is the filling point
A level plug is located on the transmission in front of the right axle. Fill through three bolt cover plate until it starts to spill out level plug.
