ZTU oil lines
Dennis P
I need to replace the nails in the oil lines above the valves. Are they available & where? I have been installing new felt and using safety wire. This not only holds the felt in place, but I use the twisted end to direct the oil onto the valve area. This works if the nails aren't broken up into the line (which I have) and I'm concerned about to much oil flow. I guess too much is okay if it doesn't affect oil overall pressure. I suppose that I could use a round nail in the square hole to slow the flow. Anyway, I would still like to find the original nails.
You should be able to go to a hardware and get some large carpet tacks (nails). I got some about 14 years ago for a R I was working on. I gave the rest to a friend when I lived up north.
