a4t at auction
The recent 1400 at auction did have turbo but was not installed at the factory on that serial number. It's not one of the 50 produced at the factory.
Do you have a serial number list that shows specifically which numbers had the turbo from the factory? I had not heard any numbers before. I have an A4T 1400 with the 504 turbo but I don't know for sure if it was original from the factory or added later. I would be very interested to know for sure, and a serial number list would be very helpful.
None came from factory with turbo. All were shipped to dealers first. If turbo was requested to bring 115 to 140hp motor was changed. A crate motor was shipped and changed. Turboed motor runs higher rpm and uses a different injection pump. 10A29879 was called a high elevation pump an was used in conjunction with turbo. So check your pump number. All 1400's were bubble nosed.
(quoted from post at 12:39:37 12/20/18) None came from factory with turbo. All were shipped to dealers first. If turbo was requested to bring 115 to 140hp motor was changed. A crate motor was shipped and changed. Turboed motor runs higher rpm and uses a different injection pump. 10A29879 was called a high elevation pump an was used in conjunction with turbo. So check your pump number. All 1400's were bubble nosed.
I believe BMG1 gonna win this one !!!!
Are you interested in an A4T that is sitting unused? Don't know condition. I go by it once in awhile. Could probably find out about it if you want. I'm in Central MN.
