Company Logo Shop Now
TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
model U
avant 1735
12-03-2018 17:07:10
OK, I guess someone needs to explain serial numbers for a U to me. Tractor data shows 6 serial numbers, Minnieapolis moline.com shows 12 numbers. my tractor has 8 numbers on the id tag. I have compared my numbers to tractordata @ MM.com and find no consistency. What Am I doing wrong? Signed confused!!
Rich'sToys
12-06-2018 06:05:37
 Re: model U in reply to avant 1735, 12-03-2018 17:07:10
When you get a chance, post a picture of your tractor.
avant 1735
12-06-2018 05:39:52
Thanks very much for your help.
mmfan55
12-04-2018 19:09:53
Sorry avant. 55. What I get for trying to read small numbers in poor light. Not off far.
ChrisQ
12-03-2018 20:26:58
1955 UTS by this list. http://jetstar.minneapolis-moline.com/mm-tc_serials.txt. Moline serial numbers varied length by model. So a designated UTU had a 6 digit number, earlier UTS was 10 digits, later UTS was 8. Pretty sure there was no rhyme or reason as to why. The first 3 digits for a Moline serial number I believe indicate model for the most part. So match that up in a list, then go from there.
mmfan55
12-03-2018 19:38:15
My books show that as a 1954
avant 1735
12-03-2018 18:49:43
The numbers I have (01213846) are located on the transmission housing on the right side fo the tractor. Thanks
rvirgil_KS
12-04-2018 06:39:24
 Re: model U in reply to avant 1735, 12-03-2018 18:49:43
UTS Yours would be 1955
1948 0124800001 - 0124802276
1949 0124900001 - 0124903901
1950 0125000001 - 01203850
1951 01203851 - 01207138
1952 01207139 - 01210570
1953 01210571 - 01213219
1954 01213220 - 01213325
1955 01213326 - 01214125
1956 01214126 - 01215100
1957 01215101 - 01215150
UTS is the standard or fixed wide front end. 012 is model designation rest is sequence number
minnemoblb
12-03-2018 19:29:32
The serial number you posted is for a 1955 UTS.
t.r.k.
12-03-2018 18:32:52
Are you using the numbers off the correct tag? MMs had a tag for both the engine and the tractor, and those numbers don't match each other.
It would help if you post the numbers you have.
I am thinking that the tractor tag is between the throttle and the belt pulley (or belt pulley 'delete' cover, if no belt pulley.) on the right side of the transmission case.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
